Used when ospf ignores deleting one route from kernel routing table. %ip%: the IP address of the destination. %mask%: the IP mask of the destination. %gw%: the next hope address of the route to the destination. %cost%: the cost to the destination. %area%: the associated area of the destination route. %proto%: the route type, it could be intra-area, inter-area, extern-1 or extern-2.
None. This is for debugging.
Debug-Verbose
Ignore deleting dst %ip%/%mask% gw %gw% cost %cost% area %area% %proto%.
| Name | Type |
| ip | IPN |
| mask | IPmaskvalN |
| gw | IPN |
| cost | uInt |
| area | IPN |
| proto | String |
